Thedivergent03
Jun 2017
Spokane, Wa, Usa
John B
Dec 2015
New Jersey
Just out of curiosity, what kind of vacuum line are you losing? It's possible that the line is collapsing and the wastegate is never seeing boost reference if the vacuum line material is too soft. Another possibility, (although not likely in this case) is that the wastegate actuator is stuck closed. Let us know what you find out
