On my 88 I ditched the EQ and dont have the pocket that normally would go there instead. I need a spot to run a few gauges and I know some guys run it there vs a gauge pod or screwing it to their dashboard. Mainly what I was curious about is..are you guys screwing a gauge pod plate directly to the plastic radio bezel or are you guys mounting it somehow behind it and getting it to line up with the old eq spot?? Pics would help out alot if you guys got any..already have a SN95 dual pod that has a Oil pressure/boost gauge. I need a wideband soon and since im at it might as well do water temp and idk volts since all my gauges are incorrect lol.
88 5 speed TC
