I have an 88,the gauges(alt,fuel,temp,oil)all went down,and the low fuel light came on.I was wondering does anybody know what these 5 things all run though together,that went bad?
Not sure but check fuse #18
all the fuses are good,thanks though
Allan S
Clemmons, NC
Mine mine did that I had to replace the ignition switch. If that is the cause you will know for sure if you procrastinate like I did because other things will eventually quit too. (stereo went out next and then AC went out which is when I got it fixed)
