i have a problem with the gauges in my new bird.
when i first start the car the amp gauge goes all the way up to the C mark and then slowly backs down to a little bit above the middle,
and after the car is warmed up, the temp gauges is right on the r in norm but then everyonce in a while the it will start shooting up to the H and then come back down after about 5 seconds or after a good smack on the dash..
is this gonna be the IVR???? also im replaceing my heatercore and i was droping the steering column i unplugged pigtail from the ignition switch to find that 2 of the plugs in it are melted, its the two in the middle on row closest to the left side of the car could this have anything to do with the gauge problem?? also i just got done removeing an aftermarket alarm that some half assed electrtion put it it was also wired to the ignition switch could that have caused the heat damge i found in the pigtail??? i looked at the switch from my other 88 with over 180k miles and it looks brand new compared to the switch with only 110k miles should i replace the switch and pigtail??? thanks in advance
[This message has been edited by TCEATHONDA (edited 10-10-2005).]
88tc ac delete, flowmaster exhaust fluidyne radiatior, gillis,
