Jeffrey Daly
Feb 2009
Wakefield, MA
Does any company make a gauge pod for our TC's???? I need a two gauge pod for my windshield pillar.
1988 Ford Thunderbird Turbo Coupe 5 speed/ Gillis Valve/ 140mph Ford Motorsport gauge/ RAM Powergrip Clutch/ K&N Cone filter
To the best of my knowledge nobody make anything specific for the Tbirds.
thumper
Jun 2001
Dexter, MO
Some have said that the ones for late 80s, early 90s Mustangs work with a little trimming.
A.K.A. Corey Bennett
87TurboBobby
Dec 2006
Colquitt,Georgia
94 Mustang. That's what I used.
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
xcrunnerbd
Oct 2006
Woodland, MI, USA
That's the one I have as well. It isn't on the car yet but I've done some test fitting. It isn't perfect but minor changes will make it work.
I think I ordered mine from Summit.
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
Jeffrey Daly
Feb 2009
Wakefield, MA
So go with a 94 Mustang unit from Summit?
87TurboBobby
Dec 2006
Colquitt,Georgia
That's the closest fit you'll find unless someone custom makes them.
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
I'm working on fabricating a dual 2 1/16 gauge holder for the steering column...when i have one done i will post photos.....
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
Tom Senior
Feb 2009
Ridgefield CT
Tom junior runs the body shop and he uses the one pete suggested. Then he molds it into the pillar piece with some sort of stuff. (its secret body man goo i think) Then paints the whole mess to match the interior.
