i have an 88 TC I just noticed the fuel tank is leaking. I figured no problem I ll fix it. I crawled under it and have found the metal fuel lines are rusted so bad I dont think I will ever get the plastic tank lines loose without causing another leak somewhere else. Ford tells me the fuel lines were discontinued in 95. I have no problem running hard line but what is the best way to recconnect the factory plactic lines? I would prefer not cutting the ends off and hose clamping them.
