gages not working
Donnell Offline
Fuel volt and temp is not working need help and fog lights keep blowing fuses................
Donnell Louis
Volt gauges seldom work. Do the fuel and temp gauges work at all? Do they go up and down erratically? What does the oil gauge do?
HOODBIRD Offline
Hey pete
I looked at his car the other day he has no volt, no temp, and no gas right nell? I was thinking its the ivr. The gages are not moving at all but he has tach, speed, and oil.
He has a nice bird in the workings.
86tc 5speed k&n, gfb boost controller, autometer gauges, tripminder, fmic, and upgrading as fast as possible
If the oil gauge works, the problem is NOT the IVR, as the IVR feeds the oil, fuel and temp gauges. Is the wire connected to the temp sender? Fuel sender could be bad also. Might also want to check the connectors to the cluster to be sure they are clean and tight.
HOODBIRD Offline
Thanks jeff and also the cluster wont light up.
His 88 makes me want to buy another bird
