Harvs
Jun 2002
Ware, MA
I got my g-tech yesturday (looks like it was made cheaply), didn't get to test it yet. (Who ever bought one), did you try it, i'm just curious on what everyone got for times?
rpratt
Apr 2003
Grand Rapids Mi.
I was surprised, I thought my car was faster than it says ( MUST be wrong : rolleyes : ). I got a 16.08 spinning halfway through first, but that was my fastest. When I got traction, it bogged pretty bad and usually runs 16.40s.
I really thought that I would be in the middle 15s. I have only run it a couple times, with some practice, I'm sure I can dip into 15s, but they will still be very high 15s.
mustangtyy
Oct 2001
Findlay, OH
I got mine and it seems ok. I made a few runs, best was a 15.35 followed by a 15.95 (bad take off) and 15.47. I just put my ported e6 on today and I have not made any runs with it. Ty
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, Paxton AFPR, GN FMIC, RR Cam, T3 at 20 psi, OBX BOV, Spec Stage III Clutch.
Harvs
Jun 2002
Ware, MA
are your cars mostly stock? 16 seems pretty stock
mustangtyy
Oct 2001
Findlay, OH
I have 87 tc, k&n on vam, gillis 17 psi, sac mustang dp 3" super turbo dumped before the rear axle, and now a ported e6. The little driving I did today the car feels alot smoother and stronger with the e6. I hope to be in the low low 15s. From the tech articles a stock 87-88 tc runs a 16.8. So around a 16 flat is still a good improvment. Ty
turbocoupes
Jul 2003
Aberdeen,Maryland
Natmac bought one and we set it up on my 87 TC. Seemed to work good for us ...16.8 with engine hesitating under heavy boost[20+]next try with feathering throttle and came up with 15.8 with 18-19 lbs. boost...if nothing else it's a good tool for cking the mods and the improvements [or not] they make...money well spent for us...just can't seem to get to local track that much anymore...
Garry McVey Birdoprey always in flight
83 86 87 87 87 87 TC 87 XR4ti
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Glenn 88TC
Lebanon, PA
We need to all hit Cecil County next spring. I used my G-tech to time a 16.4 at 84.5mph. This was in a co-workers bone stock 2002 Neon.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
rpratt
Apr 2003
Grand Rapids Mi.
Yeah, mine is stock except for a K&N and gillis valve. I think the worst thing on my car is the stock 2 1/4 to 1 7/8 exhaust.
natmac3
Mar 2002
Aberdeen, MD
The one thing to remember when using your G-tech is that it's only as accurate as the variables you test in.
Always test on as close to level ground as possible. Always test from an absolutely dead stop. Always test on the same stretch. Always run at least 3-5 times and average the results.
This will ultimately yeild the most accurate readings...
--n8
1987tc
Monte
Nov 2003
las vegas
I have done a lot of tuning with the g-tech. There is one very helpful feature if used consistently. The Hp setting. I have used the Hp setting for performance tuning. I have found that its results are more consistent than using the qtr setting. I put it on the Hp setting and roll very slowly off the line till I hit 3,000rpm. I then go to WOT till I hit the shift light (@6500) go to 2nd and then let it carry all the way to my rev limiter which is set at 6800rpm. I then record the hp reading. I do 2 runs that way and record the results. The run back is usually a little larger then the first. I then make changes in timing, jetting, etc and record the results. Now you have to be consistent in your driving style other wise you are wasting time. I have used this method with many vehicles and found it to be very helpful. About the only thing it wont tell you is if you running flat at the top of the track. But with that method you can do a lot on a fairly short street. I have also run the g-tech vs the track. Results do very between g-techs, but mine was usually within 3-4 mph (g-tech was always higher) and within .2 to .3 (both higher and lower than the track) in the quarter. My application is a sbc in an automatic car. In stick applications is varies a little more. Monte
[This message has been edited by Monte (edited 11-27-2003).]
