Tbird73
Oct 2012
Tyler,TX
I had a boost problem. I couldn't boost past 10 lbs without the car bogging down. ... turns out the previous owner gapped the plugs at .24. I regapped them to .28. .... Problem Solved!!!! :-)
Greg Corriveau
1987 Black TC stock
God is First ...... I am Second
Plain and Simple!!!
BJL
Williamstown, New Jersey
awesome, thanks for sharing this!
hows it feel to really run her now???
Brian Larkin
88TC 330,000 miles
Slightly Modified
I run my NGK 2238 plugs at .032, and have no problems at 24 psi boost. I do run an MSD E core coil. While it has questionable reliability, the Ford TFI ignition system produces a good strong spark.
Joe F
Jul 2002
Hawkins, Texas - USA
I believe the stock gap recommended is .034", at least that's what I always used when my ignition system was stock.
With an MSD 6AL and Blaster coil, I gap my plugs at .045" and it runs great - smoother than it ever ran with the stock ignition system.
Just my 2¢ worth. mokin:
boosted chicken
Jan 2006
Odessa, Texas
I have gapped mine as tight as .018" before. It currently is at .020". I'm running just under 30psi with E-85 and even with my MSD coil and MSD 6530 box, I wonder if I could even run much more.
I know its not apples to apples..
Tbird73
Oct 2012
Tyler,TX
So the more fuel pressure and boost you have the smaller the gap on the plug?
Greg Corriveau
1987 Black TC stock
Plain and Simple!!!
The higher the cylinder pressure, the harder it is for the spark to jump. Fuel pressure has nothing to do with it.
Tbird73
Oct 2012
Tyler,TX
Oh ok, thanks for the knowledge!
Greg Corriveau
1987 Black TC stock
Plain and Simple!!!
