KMcGrathNJ
Mar 2002
Bear, DE
I was out enjoying my TC today, has anyone else noticed how smooth they run at 80mph?, anyway I started to notice a sound when the boost reaches 8-10psi, sounds like a fluttering rattle, like maybe the fan is coming loose or something similar. I really don't know a damn thing about a turbo, I do know its the stock turbo, is this something I can take apart and look at or does it need real help?
Kevin
88 TC man. tran. White/Burgandy All options exept Leather and spoiler; K&N cone filter; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors.
Near Future - Gillis boost control; High flow cat, 3" straight thru.
88 TC Auto putting on a few band aids to make daily driver so I can work on other TC.
Kevin
88 TC T5;White/Red; All options exept Leather; Front Mounted K&N cone filter; 140 Speedo; Superchip; Gillis Boost Valve; Custom vac/boost-volt-temp gauge cluster in console Ground Effects; Spoiler; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors; Infinity 5 1/4 component in rear deck;
Rockford 10" sub; (2) Alpine amps
Near Future -Paint
Take the zip hose off the compressor inlet pipe and then take the inlet pipe off. Look at the compressor blades, at the ends, for any chips or broken blades or blades tha are badly erroded. Try to move the shaft back and forth and from side to side. Much movement in either direction is bad. Do the blades contact the housing while you are tying to move the shaft. If so it is time for a rebuild or an upgrade.
[This message has been edited by Pete D (edited 04-25-2002).]
DennyMishler
Apr 2002
Montague, NJ USA
I noticed that when my timing is off, it makes a rattling noise when I get on it...I'd check that first [Image: wink.gif]
Rodger
Jan 2002
Palos Heights, IL.,USA
I had similar noise that also happened in the middle boost range. The noise seemed like it came from the right side area of the engine compartment. The noise stopped immediatly after I converted to a Gillis valve and de-activated the BCS.
KMcGrathNJ
Mar 2002
Bear, DE
[/B]
Pete I love the optomisim, not really a problem, its an oppotrunity to upgrade!! [Image: tongue.gif]
Kevin
Kevin
Near Future -Paint
That should be:
Quote:...time for a mandatory rebuild or an upgrade.
"Well, honey, it's still less expensive than if I took it to the dealer to fix and I can put off buying that BBQ grill."
