fuel tank
Reamer Offline
any body know a part # for the filler neck gasket/seal on the tank side?
also tempo sending unit yeah or ney
88 T/C,blue/blue leather, built a4ld w/stall,kirbin,walbro,nx halo spray bar,k/n,gilis,2.5 exhaust
97 xr7 v8 sport loaded 5spd,pi top,tuned,3.45's DD 25mpg
07 gt mustang 5spd all stock
68 mustang jcode
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt."
BJL Offline
Moderator
i order one for a 96 mustang. i had to change one in a 96 stang a few years ago and saw it was about the same and ordered and tried it. worked out perfect.
i used F4ZZ-9072-DA i think it was like 25 jobber cost. i dunno if its more now since this was like 2006
Brian Larkin
88TC 330,000 miles
Slightly Modified
Reamer Offline
looks like it should work...thank you
68 mustang jcode
Huey866 Offline
Make sure you rub oil all over it, makes everything slide in much easier.
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
