fuel switch
cloud17 Offline
87 turbocoupe auto.........my fuel switch doesn't work. the light dont come on when i put it on premium and when i did put 94 oct and tried it i didnt feel anything different. is there a fuse for that or some way i can fix it? how far does it advance the timing?
Maybe the light's burned out. Did you check the timing with a light with the switch in each position, sprout in place.
There is a fuse, but if your speedo and tach work, the fuse isnt the problem, as the fuel switch / fuel relay are on the same circuit that powers the speedo and tach. I agree with Pete, likely the bulb is just bad.
Drop the glove box door, and near the left side of the opening, you will find the fuel relay (should be medium blue color with 4 wires to it) With the key in the run position, turn the fuel switch on/off while you listen to / feel the relay. The relay should click on and off with the switch.
cloud17 Offline
i put some 93 octane in it and checked for that noise. didnt hear anything. i also checked the timing just incase and it was still set the same. can anyone help me?
cloud17 Offline
oh bye the way thanks jeff for all that info you sent me. mine was running 18psi in 1st n 2nd and 15psi in 3rd n 4th. im gonna try and hook it up like you said for full boost in all gears this weekend.
mustanglover32 Offline
Ya mean that the fuel switch changes the base idle??? Well no friggin wonder my timing seemed off!! BTW, about how many degrees are we talking here between reg and preium?
later,
david
Wings are for planes!!! (I would know I fly them!)
TurboCoupe50 Offline
You can't hear/feel that relay click. It doesn't have a std coil and contact arrangement. It has a reed relay inside a coil with a 56 ohm resistor in series with the contacts. I found this out, when I wired up my prem fuel switch to arm my nitrous system. Needless to say my relay died with the explority sugery.
Three 1988 Turbo Coupes .....
yea one of em has a 5.0 And runs 13.1s......
uhhh make that [email protected] with a 90hp shot of nitrous.
[This message has been edited by TurboCoupe50 (edited 05-15-2003).]
1988 Turbo Coupe331 AOD
1972 Comet GT
Tom, I can hear the relat click in my TC if it is dead quiet inside the car, and I put my head a few inches from the relay and operate the fuel switch. Of course, a better way to test it is to use an ohm meter to see if it grounds (to SIG RETURN) the corresponding pin on the EEC (pin 34??? I dont remember off the top of my head).
Dang Jeff, you must have some good hearing! (I can't hear for crap anyway).
1972 Comet GT
