Fuel regulator
88turbobird5 Offline
I have an 88 turbo coupe what are people using for an after market fuel regulator with a gauge on it
Not B Anymore Offline
I don't know about one with an integrated gauge, but a lot of people use the Kirban regulator, and a gauge can be hooked up at the schrader valve.
I have a Kirban FPR, and have an Autometer electric fuel pressure gauge and a Autometer boost gauge both mounted on the A pillar. Very easy to watch fuel pressure rise and fall with vacuum / boost.
A fuel pressure gauge under the hood isnt going to be very useful, since all you can do is see fuel pressure at idle or free revving the engine.
88turbobird5 likes this post
Would either one of you guys have a part number for the kirban regulator that would work on my 88 tbird. And how did you mount them on the a pillar i was trying to find something close but no luck and im new to the thread. Thank you gentelmen ?
Same FPR that fits the 5.0 Mustangs and most other Ford products from the 80s thru the mid 90s.
No one makes a replacement A pillar with gauge mounting holes for the FOX3 Tbirds, but you can get a generic plastic one and trim it / massage it to fit pretty good.
Thank you jeff i really apperciate all the help
