I need Help with my fuel pump. What is the best and the cheapest that i can get. I have found mustang 5.0 stuff but can u all give me some good links to go to.
Blade1433
Jun 2001
Columbus, Ohio, USA
Do you want stock replacement, or performance? The Walbros can be had for $120 or so, or less with careful shopping. If you need it REALLY soon and have an Advance Auto Parts nearby, they can order a Federal Mogul 190gph fuel pump, runs about the same price as Walbros and will be there the next day. Just ask for one for a Mustang. I'd have the part number but seriously threw the box away this afternoon! While it's all apart, change the strainer and in line filter. You may also want toflush the tank out to remove possible rust or deposits, just don't blow yourself up
http://www.jdsperformance.com/index.asp?...inmake=all
See GSS340 or GSS242 or GSS307 (all are for 85-97 Mustang)
Glenn 88TC
Lebanon, PA
What Pete said.
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
http://www.need-4-speed.com/kirban.htm
K-5005
A adjustable regulator for that same year will work then right..
16psi,func. gauge pod,k&n,exhaust no cat
[This message has been edited by Butterbeanjr (edited 02-14-2003).]
natmac3
Mar 2002
Aberdeen, MD
This is the right one...
The one in the pic you posted doesn't look right at all...
If you don't order from JD's, try to get in touch with Motormenace, I think he might still have connections to get'em...
[This message has been edited by natmac3 (edited 02-14-2003).]
1987tc
once again thanks guys i am gonnna go ahead a order the pump and regulator now.
