turbobird
Pontiac,MI.
If I splice a on/off switch in the F/P wire to the EEC will it turn it on/off or just the signal? Just trying to avoid running anymore wires through the firewall, thanks.
Jerry R.
88'Turbocoupe
TurboCoupe50
Chesapeake, Va
Grounding pin 22 at the computer completes the circuit for the F/P relay, so the pump should run. This assumes the ign sw is on and the EEC relay is energized, as it feeds voltage to the F/P relay and the EEC provides a ground path.
Three 1988 Turbo Coupes .....
yea one of em has a 5.0 And runs 13.1s......
uhhh make that [email protected] with a 90hp shot of nitrous.
