Fuel Pump Install Question
Mikey97D Offline
1988 Turbo Coupe
My pump failed so I am installing a Walbro 255 lph.
The filter on the end fits differently since our tank pickup is at an angle compared to the Mustang I suppose that the pump is made for.
Original Filter:
[Image: UK7LHBJm.jpg]
Filter from the kit:
[Image: 3YOanclm.jpg]
Do you think I should trim the rubber on the end of pump isolator so the filter sits flat?
Here's the picture of the isolator that protrudes:
[Image: zSxN1Wrm.jpg]
Mikey97D Offline
Or is this the rubber isolator that was warned not to use because the fuel can't be picked up as easily (too low)? Previous owner did change the pump once before me.
BradM Offline
(07-16-2021, 09:05 PM)Mikey97D Wrote: Or is this the rubber isolator that was warned not to use because the fuel can't be picked up as easily (too low)?  Previous owner did change the pump once before me.
I believe I just used the sock from the old pump on the new Walbro pump.
Mikey97D Offline
The old sock does not fit on the new pump very well. Very loose.
Mikey97D Offline
I cut the rubber on the bottom of the isolator with a hacksaw so it does not have astep anymore. The new sock/filter fits much better.
