88Tbird2.3t
May 2006
Seattle, WA
Does anyone know where the ground for the fuel pump runs to?
im assuming it grounds to the chassis somewhere but was wondering if anyone knew where?
88 TC
Best run: 1/8 - 8.062 @ 87.91MPH, 1/4 - 12.564 @ 109.44 MPH *(10/17/12)*
BJL
Williamstown, New Jersey
07-18-2013, 04:47 AM
(This post was last modified: 07-18-2013, 04:50 AM by BJL.)
to the body, he he he he.
alldata says right hand floor pan
Brian Larkin
88TC 330,000 miles
Slightly Modified
If my old guy memory is working right, I think it grounds under the back seat on the pass side. Pull up the trunk carpet. You will see a orange (I think) wire running thru a grommet on the vertical wall of the trunk well facing the front of the car. Thats the FP ground. I tapped into this wire (stripped insulation and soldered on a "extra" 12 ga wire) and grounded it inside the trunk for an extra pump ground.
BJL
yes orange ground. i agree.
Brian Larkin
88TC 330,000 miles
Slightly Modified
88Tbird2.3t
May 2006
Seattle, WA
 thanks that sounds about right to me, havent pulled up the carpet to check yet but pretty sure ive seen it before. Still waiting for some spools of new wire to come in to rewire the entire fuel pump
88 TC
