FUEL PUMP
pdeetz88 Offline
I am about to drop the tank on my car have a Bosh unit going in. Is there any drawback to not using a Walbro pump. I will not be doing any mods to this almost perfect coupe. Also did all 88s have a serv engine soon light mine does not come on at start up?
Also my anti lock light stays on and the brakes work fine.
1988 all original 71,000 miles. Perfect condition all factory options including raven leather and moon roof. no mods nice example of a TC!!!! TOO BAD ITS A AUTOMATIC!! Real strong and smooth has ranger update.
Tom Senior Offline
Banned
Yes to ses light. I use a 255 in all my ford builds. I have used bosch pumps on stock instillations with very little problems. Just make shure you change the fuel hose in the tank with a nigh quality brand. They have a nasty habit of splitting. If you have the option spring for the 255.
The antilock can be not working and the regular brakes work fine,
See http://www.tbirdheritage.com/turbocoupe/articles/
OU812MACH1 Offline
if its the same as a foxbody stang, u can get a pump from napa #p74105hp 44gph/93psi
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
Wjameson Offline
I bought my 255 walboro delivered to the door for basically the same price as a stock unit from NAPA Auto Zone etc...
Bill
87 TC 5spd, 2006 Daytona R/T Charger,03 Anniversary HD Lowrider
87TurboBobby Offline
Yeah and sooner or later that GO FAST, MOD. Bug is going to bite. Then you wish you would have used the Walbro 255HP.
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
OU812MACH1 Offline
i use 255l in stangs with charger/turbos...it just seems over kill for 4 injectors even if 65lber's....but hey , for the same price i prob will use a 255l when i have to drop the tank. mine is 87 factory oe...surprised it still works
pdeetz88 Offline
Went with the Bosch unit because of availibility I had to wait a few days for the Walbro. Thanks Guys!!!
