fuel pump ?
Pat Fay Offline
Hey, my fuel pump is shot, so I was wondering what pump should I get? And is there any kind of relay or inline fuse to the fuel pump? Thanks for your time.
Pat
[email protected]
1987 Turbo Coupe
Mod's -
~ K&N 6" Cone mounted in front of radiator, JVC Kameleon CD Player, Neon Shifter Knob, Neon Light in back, New Kenwood 3 1/2" and 5 1/4" speakers, New 6x9s, Blackout Lights in front, 2 1/2" chrome tips on exhaust, Gillis Valve set at 11 psi (its low because my clutch is slipping...once thats fixed goin to go to 18psi), Single gauge A-Pillar Pod w/ boost gauge...
SteveX82 Offline
Several other people on this board have suggested this Walbro 255lph hi-pressure pump: http://www.jdsperformance.com/index.asp?...&fcmd=item It's designed specifically for 5.0's, but I've heard nothign but good reviews from the other guys about it(except for a few problems regarding the installation and leaking of the seals, but i'm sure those were just flukes that could happen with any pump). I actually just got my pump in the mail this tuesday and will be installing it two weekends from now. One extra thing you'd have to get if you decide on this pump is a larger bracket-to-tank seal (it comes with one for a 5.0 that's only abotu 2 1/2" wide, when you need one that's something like 4 1/2" or so)
maroon 1987 TC 5spd
gillis valve set at 18lbs, k&n cone on VAM, removed A/C belt, unbolted exhaust at track,
best 1/4 mile: 15.10 @ 89.25mph
UPDATE: car blew the turbo on 8/17/01, so it'll be off the road until next summer when i can fix it.
The fuel pump relay is one of five in the Integrated Relay Control Module (ICRM) which is the big black box on the front of the passenger side strut tower.
Pat Fay Offline
Fuel pump is in, I just got an OEM fuel pump and relay. Replaced them and the car is back up and running. Thanks for your help.
Pat
[email protected]
1987 Turbo Coupe
Mod's -
