Eliminator SS
Feb 2013
Nebraska
Just wondering if there is a way I can attach a fuel pressure gauge to the stock fuel rail's pressure port? I figured if anyone has done it someone on here would know what fittings are required.
1971 Camaro RS/SS, Built 355 Small Block, 426hp. Muncie 4spd. Ford 9" rear.
1979 Camaro Z28, 1974 Corvette LT1, TH350, WS6 TA Rear Axle.
1997 Mitsubishi Eclipse GST, AWD Conversion, Built 6 Bolt 4G63T, Custom FMIC, FP3065 Turbo, 579hp.
boosted chicken
Jan 2006
Odessa, Texas
If you have a fuel gauge kit, it should have everything you need.
You should just have to unscrew the schrader valve and screw on the fitting supplied in the kit.
88 TC#1 2.9L tall deck. Essy SVO head, Boport header, BW SX369 turbo, C4 trans, MS2xtra
88 TC#2 drag car project(someday)
88 TC#3 parts car (just needed the header panel...bought the whole car, lol)
Eliminator SS
Feb 2013
Nebraska
OK I dont have any kits but a few gauges. I probably have the fitting somewhere. Might be easier to buy a new kit.
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
You need a fuel pressure gauge for a 86-93 5.0 mustang...should be available at summit.
Travis
squeeky
Feb 2013
north carolina
86XR7auto Wrote:You need a fuel pressure gauge for a 86-93 5.0 mustang...should be available at summit.
Travis
what Travis said.... http://www.summitracing.com/parts/acc-74...el/mustang
88 turbocoupe, gillis valve, k&n, short throw shifter,3" exhaust with magnaflows,Garrett(turbonetics) T3,AFPR,18lbs boost for now.....
You might get lucky at a pep boys with a "performance shop" also if they have one in the local area or a good local auto parts store if needed right away
-88 TC Black
-97 Pathfinder
