Fuel Pressure Gauge adaptor
88tbirdtc Offline
I have a Kirban fpr that I am planning on installing soon and my friend gave me a summit racing fuel pressure gauge that he had and never used. He doesn't know anything about it or how to use it and neither do I. Here is a picture of the gauge and its connection.
http://natomessageboard.com/uploads/0000...titled.jpg http://natomessageboard.com/uploads/0000...itled1.jpg http://natomessageboard.com/uploads/0000...itled2.jpg
Now i am not sure what kind of connector I would need so that i can hook it up to the schrader valve so i can install my kirban. I dont even know if this gauge will work. I just wanted to see if anyone could help me or give me a link to an adapter that would work or show me a gauge that I could get that would work easier and better. Thanks!
88 turbo coupe: 117k, K&N cone, Gillis Valve set at 17 psi, Walbro 255hp fuel pump, Kirban AFPR, and FMS 140 mph speedo.
75 Pontiac Lemans Sport Coupe: My future project.
thumper Offline
That looks mechanical... right? Which means running a line to whereever you install the gauge... i.e. the dash.
I wouldn't plumb my gas all the way into my cabin. Maybe I'm not seeing it right.
A.K.A. Corey Bennett
88tbirdtc Offline
Yea its a mechanical gauge. But i wasn't looking to install this one in my car. Sorry i didnt say that. I just wanted to use it to set the base fuel pressure for the kirban and thats all. I was probably going to get an electrical autometer gauge to mount in my car for later. Right now i just want to install the fpr.
turbot79 Offline
look in a jegs catalog in the mustang section i believe there is a connector that will work for you
88 tc, hbc, t3t4, 3"throttle body,3" stinger exhaust, msd, 18psi, Tial 50mm bov, Esslinger adjustable round tooth timing kit, rods header on the way and many more to come
RDOG Offline
I just went to home depot and got the brass pipe tubing. cost me around $6. bring your valve and they will help you match it up.
Ra Offline
Like RDog said all you need is a pipe fitting, if you have a good plumbing supply store they should have it. You need a 1/16" NPT Male X 1/8" NPT Female adapter. If you get it from jegs the number is 555-41062 for ~$3.50.
stock except for a K&N Cone
88tbirdtc Offline
Is that all i need then is just an adapter from jegs or home depot? or do i need another piece to connect it to the schrader valve? The main thing that i am wondering about is that it seems like there is a screw in the connector on the gauge and i dont know what to do about that.
Ra Offline
With the fitting i'm refering to, you will have to unscrew the schrader valve from the fuel rail. Then you screw the fitting in with the guage on the other end.
Don't worry about the screw in the connector. Most guages will have that.
