I have been wanting a better way to check my fuel pressure and make adjustments other than the Shraeder valve ones as that valve is way to difficult to get to in our cars. I already had a BBK AFPR mounted so I got a 90 degree elbow and a new Aeromotive gauge to mount on the regulator. Much better way and is easily visible for adjustments. This is supposed to be their newest version which has a small pressure relief valve on top to vent during temperature fluctuations and not get the typical liquid filled fluctuations. Set it to 42 psi without the vacuum hooked up.
