jabobia
Aug 2003
port st lucie, fl
i just tested my base fuel pressure with two different gauges and its 42psi base...56psi with 14psi boost 58psi f/p with 16psi boost
is my regulator going south on me?...would this explain the rich condition im having (rough idle - lots of carbon on plugs) and the bogging?
-james
87 TurboCoupe - 5spd
I don't think fuel pressure is the problem. 42 is in the range, but let me ask if this was with the vacuum line to the FPR connected, or disconnected.
jabobia
Aug 2003
port st lucie, fl
disconnected
-james
Harvs
Jun 2002
Ware, MA
sorry if its off topic, but im going to buy an adjustible FPR. How do i know what to set it at if i dont have a gauge?
You need a gauge to properly set it. If you don't have one and don't want to fork over $40 for one, your only option is to find a friend that has one or can otherwise get access to one.
jabobia
Aug 2003
port st lucie, fl
yeah i had to borrow my brothers...i cant afford that yet [Image: biggrin.gif]
-james
James, it sounds like your fuel system is in great shape to me. 42 psi base is just fine.
jabobia
Aug 2003
port st lucie, fl
wouldnt the 3 extra psi make it run rich?
hmm [Image: confused.gif] this is very frustrating
what else should i look at?...i assume its spark related now [Image: rolleyes.gif]
-james
Check the resistance of the ECT. It should be around 24.3K ohms at 86 *F and 5.4K ohms at 158*F. A bad one doesn't always set a code.
I'm e-mailing some info.
rairbird
Feb 2003
Toronto, Ontario, Canada
Jabobia, have you run any codes? It may help you determine the cause of your rich condition.
87 T/C, 5sp., Ported/Polished head, 1.89, 1.59 S.S Valves. Motorsport Lifters, A-234 cam, ported lower intake, Rod's S/S headers, 3" DP, T3/T04E 46, Gillis BCV, K&N Air Filter, 42LB injectors, kirban Adj. FPR, Walbro 255 FP, Diablo chip, Head and Main studs, APR rod bolts.
The next two mods are a guttted upper, and the GN intercooler, which I have but only need to install.
88 T/C stock, 5sp.
