88Turbo222
Nov 2012
Denton, TX
Ok well i put a manual boost controller on my 88 Turbo Coupe and now at full throttle it nose dives when you shift into 3rd gear. Me and my dad are thinking it is a fuel pressure problem but not sure. Is there a fuel pressure regulator or any way to turn up the fuel pressure? Or do you guys think its not a fuel pressure issue? Anything helps! Thanks Guys
BJL
Williamstown, New Jersey
double check for boost leaks. leaks can appear at higher levels of boost.
there are adjustable regulators available but first check your fuel pressure.
follow the article here and report back to us
http://turbotbird.com/techinfo/Fuel_Syst...ostics.htm
Brian Larkin
88TC 330,000 miles
Slightly Modified
