fuel line fittings---
longbedGTs Offline
Ok, I hope nobodys getting pissed at all the questions Im asking...I am in the procss of putting my 2.3 top end together with 87-88 parts...
Ive got the fuel line fittings as far into the plastic fuel lines as I can get them. See pic below: http://www.geocities.com/longbedgts/fuelfittings.JPG
You can see the left one where it has a little kinkle... I heat the line a little; twist and push the metal fitting as far as I can get it.. and same with the return line(right)
Now my question: Do those look ok to you or should I try to get the lines up farther on the barb? For the life of me, I cant get these suckers to go up any further. I used oil to lube the barb and then slip the line on...and thats the best I could get with it. ANy tips? Or are those ok?
Thanks!
87 Ranger 2.3T 5spd
(2) 88 Ranger GT 2.9 5spd
86 Daytona Turbo Z 2.2T auto trans
[This message has been edited by longbedGTs (edited 07-28-2005).]
88 TC 5spd~money pit
88 TC 5spd~78K miles
mikes87tc Offline
those fittings are a real pain in the but. When I had to replace some fitting on the rear of my car due to fuel tubes rusting out I put the plastic lines in almost boiling water for tem minutes and then my and my brother-in-law was able to just get them on. In all honesty they might be ok, except for the kinked one it will be weak there and might bust or crack at that point and then you have a gas leak. Good luck.
cougarman Offline
An easier way is to heat the metal fitting, then push the line on. Keeps the plastic from krinkleing, [Image: biggrin.gif]
Feel the Thunder !!
jeffg Offline
get some hot tap water soak the end (Plastic)line in it for about a minute pull out of water shake real quick push on
jeffg Offline
push them all the way up ,i even used a small hose clamp for extra protection
BJL Offline
Moderator
put new seals ona nd use a/c pag oil as a lubricant. also repalce the spring ring in side the other end of the fitting, you wil never have a problem disconnectign them
Brian J Larkin
1988 Turbo Coupe Gray
got turbo? I do NOW!
sequential turn signals, 3g alt,afpr, k&n,255lph pump, gillis valve, 2in dual exhuast with SN95 SS tips. tripcomputer
1988 Turbo Coupe
dark blue
needs soem TLC (and a motor)
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
longbedGTs Offline
You guys are great! I let the line ends sit in hot water for about 10 seconds, and the lines went on like butter! No leaks either!
Thanks a million! :cheers:
87 Ranger 2.3T 5spd
