BabyBlueBird
Jun 2021
Havre De Grace Maryland
Are there any fuel injectors on the market that are a similar to stock replacement. Looking to replace my brown tops.
Kuch
Sep 2016
Manlius, NY USA
you should be able to get new injectors online, Rockauto carries them
Mikey97D
Jan 2018
CONNECTICUT
Another option is to have the injectors rebuilt and flow rate checked. Often the replacements are Chinese junk compared to the OEM Brown Tops.
I had mine rebuilt at Marren Fuel Injection in Oxford, CT.
https://www.injector.com/cart/pc/home.asp
BradM
Dec 2020
Barrington, Illinois
Check out Stinger.com as well.
1965 Mercury Comet Caliente; 1968 Mercury Monterey; 1969 F100 Ranger; 1987 Thunderbird Turbo Coupe
BabyBlueBird
Jun 2021
I went ahead and has a local guy clean them and rebuild them for me. They came out like new.
