Fuel Injector "hats"
Allan S Offline
I have 3 injectors with cracked or broken brown plastic "hats" on them. Anyone know of any kits for replacing them? I haven't had any luck finding anything and the injectors worked great when they were removed from the car and I would hate to have to trash them.
SCMC Marketing Director
www.svtcobraclub.com
2004 Redfire SVT Cobra
87 TC RIP 10/2003.
The cracked hats won't hurt anything.
manifolds, polished and cc'd chambers, RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
Chuck W Offline
I've found them at places that rebuild injectors and I've heard that NAPA carries them as well.
May the Boost be with you. Always.
JT Offline
Chuck is correct. NAPA sells the "seal kit" for the fuel injectors. Each box contains 1-hat, 2 brown O-ring seals, and the yellow spacer.
They are cheap. And you probably should replace the O-ring seals. The bottom can leak air, and the top can leak fuel. If they go bad, or dont seal proper.
JT
JT
[email protected]
www.geocities.com/turbocpe/
1987 T-Bird Turbo Coupe T-5
1994 T-Bird LX 4.6L
1988 T-Bird Turbo Coupe A4LD
1988 T-Bird 3.8L
1979 T-Bird Heritage 351M
Allan S Offline
Thanks guys. Once I can get my other car put back together (waiting on stupid PCV hose that had to be special ordered from Ford) I'll go to NAPA and get to work on those injectors.
87 TC RIP 10/2003.
victrolla1 Offline
I just replaced the o-rings and end caps on my injectors with seal kits I got from NAPA. (CRB212085 one per injector @ $4.00 each) The kit has the spcacer, 2 o-rings and the end cap that gets very brittle with age.
Victor
1988 Chevy S-10 4.3 Automatic 201,000 miles and counting, 1988 VW Scirocco 16V(for sale at http://victrolla.com/scirocco, 1988 Ford Thunderbird Turbo Coupe Automatic, and 2002 Dodge Grand Caravan Sport!
1988 Turbo Coupe 5 speed, 1988 Bill Elliott Ford Signature Edition Thunderbird, 2004 Mazda 6 Sport Wagon (Zoom!), 1998 Mustang V6 5 speed.
Mr. Vanos Offline
Autozone carries a rebuild kit as well... two orings and the pintle hat. Around $4 if memory serves.
