JamesW
Sep 2004
Goreville, Illinois USA
Today I had about 1/4 tank of fuel and was going to the station to fill it up, when all of a sudden the gauge bottomed out on empty. I went ahead and filled it up but the gauge is still on empty. Does this sound like a fuel sending unit that has failed?
If so are the hard to replace, and are the very expensive?
James Westerfield
88: Black Exterior Raven Interior,190,000 Miles
Gillis Valve, Densacharger Cold Air Kit W/K&N, Polished upper from Dan E. 4 point cage, black cloth Corbeau seats
(wish I had sprung for the leather ones) 5 point Grant harness
James Westerfield
88: Black Exterior Raven Interior,196,000 Miles, 5 speed,
Gillis Valve, Densacharger Cold Air Kit W/K&N in fender well, Polished upper from Dan E. 4 point cage, black cloth Corbeau seats
(wish I had sprung for the leather ones) 5 point Grant harness.
2001 300M W/90xxx,
1998 Windstar 168xxx gotta drive the kids around
91 Ranger 2.3 W/275,xxx Just an beater to drive to work
Ford _Nation
Apr 2002
Brookfield IL 60513
Could be?...but I would check the gas guage insert in the dash first, replace it w/ one from the junkyard...much easier than dropping tank. I changed sending unit and nothing, then I checked wires,good, finally put j/y gauge in and it worked [Image: smile.gif] good luck bro.
88-TC
Gillisvalve
3" full exhaust
Custom K-N ram air
Ported Head
Kirban FPR
Walbro 255
BPV
Lakewood Drag struts&shocks
B&M short throw
85TC- Runnin 11.30's V8 style
tps87turbo
Feb 2003
Hammonton, NJ USA
Try the gauge first & see if that solves the problem. If not, then I would say that either the float has a hole & it fills with gas (That happened on my very first TC) or the sending unit finally went in the crapper.
Tony Sceia -
JamesW
Sep 2004
I put in a gauge that worked in another car so it looks like I am stuck pulling the tank.
I hope the staps dont break.
James Westerfield
88: Black Exterior Raven Interior,192,000 Miles
91 Ranger 2.3 W/260000 miles. Just an beater to drive to work
James Westerfield
2001 300M W/90xxx,
bq93
Jul 2002
Houston, Texas
Just take your time and use lots of PB Blaster.
It gets much easier after the first couple of times. Unless you recently changed the fuel pump I'd go ahead and drop a new one in. I just don't enjoy that job and I guess I'm lazier than I am cheap.
I would pull the cluster and check the resistance to ground from the sender input terminal to see what it is. Pulling the cluster is a PITA, but no where near as bad as dropping the tank. If resistance is in spec for how much gas it in the tank (about 10 ohms with tank full, about 73 ohms bone dry), you have a cluster ot gauge problem. If resistance is out of spec at cluster (probably would indicate an open circuit), trace the wiring from cluster to tank looking for a break, bad connector, etc before dropping tha tank.
Ryan H
Oct 2004
Panama City, FL
My fuel gauge quit also, and I figured out last night it was related to my broken igntion switch, which took a few console lights out, a few gauges, and my A/C. I had to keep turning the car off and back on for it to stay on. Hey! I think I saw another post last night where a guy had the same problem and couldn't figure it out. Time to go find that.
Ryan Harris
1988 TC, 5 speed, all options including sunroof
1987 3.8L V6, C4, 160K miles, no options (winter car, when it works)
RIP 1987 TC, "Built" A4LD, 119K miles, all options except sunroof
My Audio Mixes
'88 TC Walbro 255HP, Stinger FMIC, PIT BOV, Pro 5.0, Kirban, RR cam, FRPP strut tower brace, T3
Bad ig. sw. can cause the oil, fuel, temp gauges to all quit working at the same time, but bad switch can not and will not cause just one of the 3 to quit operating.
Ryan H
Oct 2004
Panama City, FL
humm.. Well, in that case, my gas gauge is dead now too then lol
Ryan Harris
My Audio Mixes
JamesW
Sep 2004
My dash is already partly apart so it wont take that much more to pull the gauge cluster out. I will gladly try that before dropping the tank.
Thanks Jeff
James Westerfield
James Westerfield
2001 300M W/90xxx,
