fuel filter location
djmikemck Offline
Could someone please tell me where the fuel filter is located. aslo where is the pcv valve locaed. Thanks in advance.
Mike
The fuel filter is in front of the tank on the passenger side of the car. Crawl under in front of the back tire and you will see it.
The PCV is near the distributor. Follow the vacuum hose that connects to the under side of the upper intake, down toward the distributor and you will find it. If your going to replace it, use only the Ford part.
Red_LX Offline
And make sure it's the RIGHT ford part too! The PCV valve on my car was allowing the crankcase to become pressurized, turned out it wasn't even the correct part number.
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'87 Thunderbird Turbo Coupe
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
The P/N is in the Parts Number Forum
