The actual sub frame that bolts to the k member is rusted out pretty good, including the bolts that connect the k member to the subframe.Does anyone make a replacement part or is it something I will have to fabricate? Thanx, Doug
live fast and drive faster
Tom Senior
Feb 2009
Ridgefield CT
That will have to be fabbed. I do these from time to time. Its not that hard but takes alot of time. The K frame is replaceable but the mounting is part of the body. How is the rest of the car??? Is that the only rusted area??? If the rest of the body is OK all you will nead is some mettal stock drills a mig lots of pizza cokes and lots of time. The pizza and cokes are optinal. Home depot has a good supply of all types of bar stock
Thanks Tom, Thats what I needed to know. That is the only rust left on the car. I just found a good deal on two doors and two fenders. That was all the rust. Can these be fixed without taking the k member out? It is just the two bolts just beneath the spring perch, other two are fine.
