jeffg
elyria,ohio,usa
Hey all,
just bought a front mount intercooler and my question is .Is it necessary to have a blowoff valve with this.were not talking a stock 2.3 .pete, lewis you know what i have. jeff
Glenn 88TC
Lebanon, PA
What intercooler did you get? I would definitely get a bypass valve. I think even a stock car should have one.
Glenn 88TC
current mods (14.096 at 97.29mph): ported & polished big valve head(1.89/1.59), ranger roller, gutted upper and ported lower intakes, t3/t4 turbo, MSD 6al, MSD Launch Control, K&N filter, Walboro 255 pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III ceramic clutch, Tiny Avenger bleed valve
Mods in progress (have, just not on yet): 65mm throttle body, 42lb. injectors, Taylor pro wires, 4.10 gears, Spearco intercooler, Nitrous system
NO TC and NO headaches.
jeffg
elyria,ohio,usa
i got a ford motorsport one,i just see some with them mounted on the intercooler tube going to tb,i have 300+hp now jsut seeing if i can get any quicker times with this.
SteveX82
Toms River, New Jersey
My last turbo broke during a 2nd-3rd gear shift after full throttle, so i've been planning on getting a bov for just the stock intercooler until i hook up my volvo front mount. Has anybody else tried this? I'm still not too clear on exactly how the bov would hook up to the intercooler itself, so can anybody fill me in?
maroon 1987 TC 5spd
gillis valve set at 18lbs, k&n cone on VAM, removed A/C belt, unbolted exhaust at track,
best 1/4 mile: 15.10 @ 89.25mph
NEW UPDATE: car is fixed and better than ever. New mods include mildly ported TB and exhaust manifold, removed a/c system (free mod, but still), kirban adjustable fpr (at whatever the stock setting is now, but changing once i get a fuel pressure guage), and a spare ihi turbo i had laying around. 14 second 1/4 mile times, here i come
I think any T-3 or better turboed car ought to have a bypass valve. no I don't have one yet but it's high on the list because of the back pressure when the TB closes. From what I have heard it seems more important with the additional plubing associated with a front mount. I would say you should incorporate one.
jeffg
elyria,ohio,usa
exactly what i was thinking with the additional plumbing thanks
Glenn 88TC
Lebanon, PA
What intercooler did you have before this?
GaryS#2
May 2001
B.C. Canada
>>>[QUOTE]Originally posted by SteveX82:
I'm still not too clear on exactly how the bov would hook up to the intercooler itself, so can anybody fill me in?<<<
I'm thinking of tapping into the end of the intercooler, seeing as there isn't a lot of room between TB and IC.
That should still release the pressure there.
Grocery Getter/Rice Cooker.
Dan E
Greensboro, NC
I believe that between the TB and (Stock) IC is a preferable location and when I ever get around to it...I am going to try to locate it on that side of the IC. This way you are returning air that has already been cooled back in front of the turbo intake.
With a Front Mounted IC there would be LOTS of room to place between the TB and IC (on the Pipe between the two...).
Dan Eaves
Dan Eaves
