Front Mount IC
deadbird Offline
Does anyone have one set up without a angled upper intake that i can see a picture of?
1987 5 sp.
- 4.6 2v swap.
SteveX82 Offline
http://www.dragtimes.com/images/1067052988engine.JPG
Estoril blue 1987 TC 5spd, 145k miles, PRofec B, walbro 255, Bailey BOV, rod's header, spearco FMIC, t3/t4 50 trim / stage III .63, full 3" exhaust, eec-tuner, 55pph injectors, wideband, Nitto 555R dr's
Best 1/4 mile: 13.282 @ 106.33 on 25psi 95oct
Jeffrey K Offline
Here is another example.
Chuck W Offline
Here's my old set-up
OLD IC SET-UP
deadbird Offline
how does this change the performance of the car. I know the obvious that it cools the air more but as far as lag and blow by? will i need a bov?
1987 5 sp.
- 4.6 2v swap.
Chuck W Offline
Lag is unchanged. You really have to try hard to increase lag on the T-3 or IHI set-ups. The lag is no different between by Tbird with the FMIC and the my XR4 with no IC.
I'm not sure what you mean by blow-by?
As far as a BPV, I'd recommend one.
This is all info that has been covered quite a bit here and at turboford....
83 TC Clone, 87 Ranger (soon to be 2.3T), 84 XR7, 80 XR7, 86 XR4
deadbird Offline
what ever it is when you let of the throttle and a rush of air flows back tward the turbo. like water hammer ( when you wana blow up fire hydrants and water mains)???? Is ther a difrence between a blow off valve (BOV?) and a By pass valve (BPV?) ? or am i really confused?
1987 5 sp.
- 4.6 2v swap.
Quote:Is ther a difrence between a blow off valve (BOV?) and a By pass valve (BPV?) ? or am i really confused?
See the appropriate article in the FAQs
deadbird Offline
Sorry Duh forget there was was in there. [Image: smile.gif] dunce cap
1987 5 sp.
- 4.6 2v swap.
deadbird Offline
answed half of my question.
BPV (ByPass Valve) vs BOV (Blow Off Valve) - What's the difference - - by Jeff Korn
BPV (ByPass Valve) - vents boost (high pressure air) back to the intake system before the turbo and after the air meter when you close the throttle under boost.
BOV (Blow Off Valve) - vents boost to the atmosphere when the throttle is closed.
Is ither one of them a must?
1987 5 sp.
- 4.6 2v swap.
