As I have posted before...I've been trying to find the source of my rough running for the past few days. I was just about to go buy a vac gauge but decided to take one more listen.
I heard a hissing sound around my EGR. I took the EGR off and discovered that I had missed the bottom hole in the gasket and it was blowing by the EGR. I got that fixed and it ran better but not great.
I ran the codes again and got a Code 21 (ECT out of range). I figured I might have knocked the harness loose while doing the EGR.
Oh, here's a loose connector...WAIT...that's a Damn Injector Connector that's not connected !!!! :O Sure enough, my #3 injector somehow got unplugged !!! Damn, I would have thought it would run A LOT rougher than it was on 3 cylinders !!! Well SOB, I plugged it in and it is a screaming red raped ape!!! The ECT code went away too (go figure ?).
Boys, it is pulling REALLY strong at 15lbs boost. Hitting 2nd gear the tires broke loose like never before...almost got the rear end LOOSE...and a never before event happened...3rd gear chirped the tires...I could not believe it !!!!
I have not been so excited since the day I bought it... YIPPPIIIIEEEEE !!!!! [Image: biggrin.gif]
Mr. Dunham had better be ready for the grudge match !!!!
88TC 5spd, Shortblock with Crower 5.5" Sportsman Rods and Short Wiseco Pistons bored .030" Over, Ported Head with Polished Combustion Chambers, Gutted & Polished Upper, Ported & Polished Lower, Polished T/B, Ported E6, SVO T3 Turbo, 3" DP w/No Cat, RR Cam, Adjustable Cam Sprocket, K&N in Fenderwell, Gillis Boost Valve, Centerforce I Clutch, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pullies, and the DAMN Heater Core is new too !
Dan Eaves
