Found a direct-replacement, bolt-in 130 amp alternator
Aaron Offline
I went to car craft summer nationals, and spoke with a guy who has a performance shop not far from hear. We looked up a 130 amp alternator that bolts right in using all stock wiring, no modifications required (although I will be adding the extra heavy power wires). I got a chrome-plated one brand new for $200. This is good news for anyone who does not feel comfortable messing with changing wires around or grinding down on the bracket.
The brand (I think) is Tough Stuff, has a lifetime warrantee, and the part number IIRC is 7716.
Aaron
1987 TC:
T3/T4 Turbo, 40Bob Header, TiAL 38mm Wastegate, SPEC Stage 3 Clutch/Aluminum Flywheel, 3" Stinger Elbow Exhaust dump, Gutted/Polished upper, ported lower, Walbro 255HP fuel pump, Kirban AFPR, ROH Snypers w/ M/T Drag Radials, Corbeau FX1 Seats, Large NPR, Forge RS BOV, 3G Alternator, MS, 75# injectors, EDIS
http://www.cardomain.com/ride/2270259/1
Ron J. Offline
The website for these alternators is http://www.tuffstuffperformance.com/
Ron
1988 Grey T/C Stocker, Original Owner. She's got 200,000 trouble free miles or at least nothing NATO didn't have answers for.
TCx2 Offline
I went to the website.. but the 7716 is a 75 Amp alt and is listed as a direct replacement for the 2.3L Mustang.
If one wants 150 Amp it calls out a 7771 3G unit that looks like what everyone is adapting to fit into the car now.
So Aaron I am confused on the direct bolt-in 200 Amp that you are referencing. Can you get some more information on what you have? I'd be interested in doing this modification.
Thanks...
Kevin
TCx2
Chas K 88 Offline
Looks like the 7771 has two bolt holes on one side, one is offset a little. Maybe we use the offset hole and it gives the necessary clearance. I'm gonna watch to see how Aaron comes out because this could be just what I need. Don't need polished aluminum or chrome for my engine now but who knows. Wink
Chas K
Aaron Offline
Well, we looked the alternator up on 2 separate occasions, and both times it came up with 7716 as a 130 amp alternator. You can upgrade to the 3G of course (the guy actually grabbed the 3G first), but I went with this one. I will call the company to double check and will report back. Assuming we are correct and this is the 130 amp alternator that I was told, this is a great option for anyone wanting to upgrade.
Aaron
1987 TC:
TCx2 Offline
Aaron,
I hope you are correct and the website is wrong.
How much did they ask for that 7716?
Kevin
TCx2
Aaron Offline
I think it was $220, but I had a $10 off coupon.
Aaron
1987 TC:
Aaron Offline
OK, here's the deal. I called Tuff Stuff and spoke with a rep, and they informed me that the 7716 is a 100 Amp alternator, so there you have it.
Aaron
1987 TC:
TCx2 Offline
Aaron,
Thanks... did you tell them to fix their website?
LOL
Kevin
TCx2
Chas K 88 Offline
100 amps ought to be enough for me. Thanks Aaron.
Chas K
