Ford to GM Steering Pump
BLKBRD Offline
Ford to GM style steering pump conversion,,
OK,, so somewhere I read about this and it was brought up in my other post.
So where do you get one and where was the thread that discussed this?
`88 Turbo Coupe Blk/Raven 5 spd
`71 Blazer slammed
`62 Impala SS 409/425
`60 Rambler American SW
`56 F-100, sold
--- several HD`s ---
Ryan H Offline
https://www.borgeson.com/catalog2/produc...9aa5f76912
BLKBRD Offline
Unfortunately these pumps are designed to be used with a GM engine in a car with a Mustang rack.
Lost of work to convert them to a Ford application.
I think the next best thing is to have the pump rebuilt locally.
Talked to them yesterday and it does look promising.
They said one of the problems with the over the counter rebuilds is they just clean the pumps and install new bearing and seals.
If you have bad hard parts the pumps will make noise.
They can completely rebuild the pump but the cost is in the $200 range, but,, I guess you get what you pay for.
My driveway looks like the Valdez,,,can`t keep fliud in the pump,,,
`71 Blazer slammed
`56 F-100, sold
xcrunnerbd Offline
Do you have a good O-ring seal between the pump and reservoir? I think this was where my old one was leaking from.. had same problem - Lots of ps fluid all over the place. New pump, new O-ring, same reservoir and hoses and now no leaks.
Shelf: .48 T3, ported E6, BPV
BLKBRD Offline
This is the third rebuilt pump with the same problem!
I don`t think the company that rebuilds them has any kind of quality control.
I do believe that is where the problem lies though, at that seal,,,
`71 Blazer slammed
`56 F-100, sold
[email protected] Offline
Banned
I use the mustang pump with the resivor on the pump. Then i eliminate the remote resivor. Serves two purposes. It works much better and there are plenty around the junk yard. And it gives more room for fromt mount plumbing. Tom
BLKBRD Offline
Quote:Originally posted by [email protected]:
I use the mustang pump with the resivor on the pump. Then i eliminate the remote resivor. Serves two purposes. It works much better and there are [b]plenty around the JR. And it gives more room for fromt mount plumbing. Tom [/b]
What do you mean by JR ? And what is the front mount plumbing?
I ntalked to a counter person I know and she said that it is common that you will have to buy 3 or 4 pumps before you find one that works and doesn`t leak!
Thats a bummer as far as I`m concerned!!
I also have a freind that has a good low mile used one I`ll try next.
What the f***,,,
`71 Blazer slammed
`56 F-100, sold
Bill S. Offline
I think he means JY, Junk Yard.
Whats ntalked? Smile
Front mount plumbing refers to air plumbing for a front mount intercooler.
'88 TC T5
'85 XR7 Roller
Mods on hold pending swap.
Stinger header & mBC on shelf
evintho Offline
Here's another option..................
Saginaw pump swap
Proverbs 3:5
Check out Thunderstang!
TurboE Offline
I bought a ford replacement from AGR. They make/reproduce steering pumps for race applications. They use tighter tolerances than stock spec, and so far my pump is quiter than any ford pump of that design i know of. I thought about retrofitting a "TC" pump as the tech refered to it as. Basically it is a GM style pump, he promised that one wouldn't ever make noise.
http://www.agrperformance.com/
Santa Rosa, ca - nice i just was in cali for work, while there drove from visalia to fishermans wharf... good to get back east tho.
-88 TC Black
-97 Pathfinder
