Ford TFI - or aftermarket
Wags88TC Offline
Any luck with aftermarket? Or stick with Ford part?
Steve Wagner
Nato member
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR,Bypass valve, 3" exhaust from turbo to tip (high flow cat/ Magnaflow muffler), A-pillar gauges(A/F & Boost), 16" ARE 5 spoke wheels(245/50VR16 Yokos'). Subframe connectors
Steve Wagner
Nato member
84 SVO
My vote is the Ford part
If you can find one, get a KEM.... VERY high quality... at least as good a Motorcraft (probably better), and somewhat cheaper. Check out www.kemparts.com
