ford motorsports injectors
dolphin1 Offline
i was wondering if anybody has a older motorsports book showing the injectors that they sold for the turbo 2.3 engines and what there rated at and the info for them,color of the plastic body and impedence.
reason i ask is that i have a set of light grey top inj's that are supposed to be rated at 42lb hr.impedence measures at 2.5 ohms and sold by FMS.
is there anybody that can confirm this or help me to identify these.
thanks
Mike
Mike
Just one white Turbo Coupe now
Glenn 88TC Offline
Check the link for a list of stock injectors on Ford cars. The grey ones are 52pph from a CFI 5.0. Check the part number to see if this is what you have.
http://www.merkurencyclopedia.com/Fuel/f...ctors.html
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
dolphin1 Offline
i dont have a part # and the only info i have is that they were sold by FMS as upgrade inj's for the 2.3 turbo's,and i know that they are not 52lb because im having problems setting them at 42lb with the tuner.
Mike
[This message has been edited by dolphin1 (edited 10-23-2003).]
Mike
Noname
Unregistered
Quote:Originally posted by dolphin1:
[B]and i know that they are not 52lb because im having problems setting them at 42lb with the tuner.
B]
As a possible last resort, why not send them off to be cleaned / flow-tested? That way you'll know they're all in good shape, and you'll know precisely what they flow at a given fuel pressure.
BCA Offline
Mike,
My Motorsport book collection goes back to 1984 and I don't ever remember FMS ever offering an injector kit for the 2.3 turbo engines.
So I went through every book and here is a list of injectors that they have offered along with the first year that it appeared in the catalog.
M-9593-A302 24 lb/hr 1992
M-9593-B302 30 lb/hr 1994
M-9593-C302 19 lb/hr 1994
M-9593-D302 36 lb/hr 1995
M-9593-E302 150 lb/hr 2000
M-9593-F302 42 lb/hr 2001
I can't help you on the colors or impedance though as the FMS books doesn't say.
Brent
1971 Ranchero GT
dolphin1 Offline
thank you very much for taking the time to look for me.very much appreciated.
Mike
Mike
fastz28 Offline
someone educate me
the TC's are high impedance?
what's the normal ohm signal reading?
'68 Z28
'94 Z28
'96 Ranger (soon to be turbo)
'87 TurboCoupe
a few other toys on 2 and 4 wheels
'87 TurboCoupe - 154k miles, b.c. bypassed, tri-ax, A-234, SC tb
'68 Z28 - custom and sharp
'94 Z28 - low-12s on stock heads/cam, low-11s on bottle, 396" LT4 ready
'00 Z28 - 377 rwhp on stock heads
'96 Ranger - soon 2B turbo, ridin' on 17" cobras, 4.10 8.8"
'89 TTA - 1 of 1555, not stock, not even close
'68 Firebird - twin turbo 383 LT1 project
http://fastz28.cz28.com
TCs use low impedance injectors with "peak and hold" drivers in the EEC. Without writing a book on the subject, the drivers basically act as current sinks. Injector resistance is about 2.3 ohms.
Most Fords, like 5.0s, use high impedance injectors with "saturation" drivers in the EEC. The drivers are basically voltage sinks. Injector resistance is about 12 to 14 ohms.
You can test high imp. inj. by momemtairly connecting them to a 12v batt, but NEVER try to test low imp. inj. by connecting them to a 12V batt, or you will burn them out almost instantly.
