? for engine builders
phyxius Offline
my engine was bored .030 but i kept the 8-1 compression, will i have to gap my plugs differently or will they stay the same.my car idles fine but still dies if i throttle it and let off completely then it is a bitch to start after.if i throttle it and bring it down slowly it will idle rough for a min then clean up .any ideas what this problem is
Dan E Offline
Plug gaps would be the same as usual around .030-.032".
Clean out your IAC and check your TPS voltage closed and a even voltage rise when opening. (Check the Tech section / FAQ's).
Dan Eaves
Dan Eaves
Also check your fuel pressure.
phyxius Offline
this is the cam i am using in my engine is it any goodor did the shop screw up by putting it in
http://www.cranecams.com/?show=browsePar...vl=2&prt=5
any feed back would be great
