cnpowell
Nottingham, MD
For the guys that need the Hella fog lights for '87/88 TC's .... I just placed an order with Joe @ www.motorsports. com. The lights are $57.95 ea. and I should have them in a couple of days.
Carl (cnpowell)
1987tc
Bicknell Indiana USA
I got my lights there too.If this is the place I think it is. The link provided doesn't work though. Came quicly and in great shape. And they are the exact ones my car came with too. Didn't have to adapt anything.
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear. lots more to come!
Linton Indiana
[This message has been edited by 1987tc (edited 05-09-2001).]
cnpowell
Nottingham, MD
That's good news .... sometimes I get an uneasy feeling when I deal with a vendor for the first time. Maybe we should give spmotorsports an at-a-boy or a high five!!!!!
Carl (cnpowell)
cnpowell
Nottingham, MD
That should be: www.spmotorsports.com. I must have had another senior moment!!!!!
Carl (cnpowell)
Senior moments are contagious. Carl got it from Dan also [Image: frown.gif]
manifolds, polished and cc'd chambers, RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
methos
May 2001
Cynthiana, KY
using those holes are great for making a custom ram air setup. If you need any aluminum sheets, lemme know. I can get the ones that we have used on the press. They have ink and newspaper info on them but who will be seeing that? and the ink comes off with solvent. I plan on using some to make scoops all across the bottom of my TC because my air dam is fubar and keeps falling off.
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods: 3.73 Gears
Finally getting it back together.
Dudleynascar
Mar 2002
Hanover, PA, U.S.A.
Also can get the fog lights here. http://catalog.com/susq/hella/us-oe.htm They have some other options too if you dont want the whole thing. I just got the lens and reflector 'cause mine was all yellowed out and crappy. They were really good to deal with also.
that's racin' (phrase): Expresses frustration or emotion. When a small part costing just a few dollars fails and stops a $150,000 race car, that's racin'.
1988 Blue T-Coupe, Stock, 175k miles
TCx2
Sierra Vista, Arizona
http://www.rallylights.com
I managed to get the Foglights.. just the replacement lens thru the above sight.
$28.06 for a single lens.
Might be worthwhile to add that one to the links as well.
Kevin
TCx2
88 White TC, 5spd, Loaded
88 Black TC, 5spd, Base
87 LtBlue TC, 5spd,Loaded
Kevin
TCx2
cnpowell
Nottingham, MD
Fog lights are in .... perfect fit!!! I didn't realize how bad the car looked until I installed the new lights .... no more broken lens/missing lights!!!!! If you order the lights make sure you hold on to the wiring harness .... you'll need it to install in the new light housing.
Carl (cnpowell)
AZTurbo
Gilbert, AZ, USA
I also got replacement lenses from these guys. Actually I think all the links mentioned really go to the same place.
I agree, these guys are OK by me. New lenses do make the whole car look tons better!
88 Turbo Coupe, Silver, 5 Speed. Original owner.
