Fog Light Problem
88BirdOfPrey Offline
Took out my foglights for inspection because ever since I got the car, they were non-operational. There was a messed up connector on both sides, so I fixed those. One bulb doesn't work. Both don't light. I checked the voltage and only get half a volt, which does not seem right at all. What could be the reason for this and what must I do to get these precious fog lights to work?
Does the light on the fog light switch light up? If so, the fuse (#7) is good. First thing to do is check for 12V at the Tan/Orange wire at the back of the fog light switch. Use a 12V test light to do this, not a voltmeter! If you have power there, use the test light to check for power across the 2 terminal connectors at each fog light.
Well, first thing, I can't tell right now and I won't be near my car until later. Should it be bright enough to see in the day time, or is that light naturally dim?
What's the reason to not use a voltmeter?
The indicator light on the fog light switch is fairly dim, and hard to see in daylight.
A voltmeter is a very high input resistance device, and will read 12V even if there is high resistance in the circuit. (A voltmeter draws almost no current from the circuit under test) A test light actually draws current (around 100 to 500 milliamps), and wil not light up if there is more than a few ohms resistance in the circuit.
