Running 100 W bulbs without using a relay to power them will quickly fry the light switch and multifunction switch.
The extra load on the electrical system will NOT cause the bulbs to burn out.... lower voltage to the bulbs will actually make them last longer. Are you sure the bulbs are going bad? the 2 prong connectors at each fog light tend to corrode and loose contact, making the lights not work.... common problem.
Any chance water is getting in the lights? One drop of water hitting a halogen that is on will kill it.
