84tbirdiso300hp
Feb 2008
new jersey
need info on what connects i need i have mustang quick connects on the fmu already and if any 1 has pics or info that would be great
84 turbocoupe stinger center mount, t3/t4 .57 trim at 18 psi,massive fmic, bob log upper ported lower, 65mm tb,cai, v8 gt spindle swap, stage 2 clutch, mgw shifter 255 lph walbro, paxton fmu, turbo xs bov, and boost controller i dont know if i forgot anything
Sluggo
May 2004
Huntingtown, MD., USA
I guess I only know the basics of a FMU type regulator. It is plumbed inyo the return line after the stock regulator and needs a vacumm line to control it. The purpose is to regulate return fuel to increase pressure in the fuel rail.
I don't beleive many use this method of fuel control. Is the one you have fully adjustable or fixed?
Doug
Why do you think you need a rising rate FMU? The PCM alreay knows to add extra fuel when it thinks boost is present.
84tbirdiso300hp
Feb 2008
new jersey
it is a fixed rate fmu
