FMIC install Phase 1
AndyR Offline
Took the TurboCoupe apart this weekend and got the Intercooler Mounted. Now I know why body shops get paid so much.
Ended up with a slight problem with the safety latch on the hood hitting the new IC bracket, but I believe that will be an easy fix.
HERE are the pictures. I can't figure out how to make images from putfile to show up here.
How's it look?
I'm really curious to hear what someone else thinks of it. I've never built anything like this before.
I was worried it would look like a hack job. Looks better than I thought it would.
The aluminum was expensive... ended up spending like $40 give/take on the aluminum and various screws/bolts, but Aluminum was much easier to work with than steel would've been... considering I used a hack saw for all the cutting Big Grin
I may take the bracket back off and paint it flat black.
And Sunday, there was a flyby over the neighborhood (see photos :])
If you don't expect too much from me, you might not be let down.
Keith Nubel Offline
Must be a big problem, you had to call in troops Big Grin
I hope you have a good cooling fan. The stock fan on that model won't pull through everything very well.
1985 TC
AndyR Offline
folk who owned it before me installed twin electric fans on it Wink
88Tbird2.3t Offline
Hey Andy,
Looks very good! Actually makes me jealous...
Heres pics of my setup that I did a little over a year and a half ago ..
www.turboford.net/cgi-bin/album.pl?album=00007156;photo_height=200
I think mine was thrown together without a ton of thought and considering that yours looks way better then mine does Smile
definately thumbs up on that, gives me some motivation to spend some time making mine little better and nicer design
Bob
88 TC
Best run: 1/8 - 8.062 @ 87.91MPH, 1/4 - 12.564 @ 109.44 MPH *(10/17/12)*
Aaron Offline
Looks good! That intercooler appears to be a very popular choice lately. Now the question - how do you like the performance???
Aaron
1987 TC:
T3/T4 Turbo, 40Bob Header, TiAL 38mm Wastegate, SPEC Stage 3 Clutch/Aluminum Flywheel, 3" Stinger Elbow Exhaust dump, Gutted/Polished upper, ported lower, Walbro 255HP fuel pump, Kirban AFPR, ROH Snypers w/ M/T Drag Radials, Corbeau FX1 Seats, Large NPR, Forge RS BOV, 3G Alternator, MS, 75# injectors, EDIS
http://www.cardomain.com/ride/2270259/1
AndyR Offline
the performance?
uh... i'll letcha know when it's done Big Grin
Thanks for the kind words y'all. Smile
AndyR Offline
I rebuilt the bracket/brace in the front of the car.
I had to cut it up to get the IC in...
The safety latch catches it and it hooks to the nose so i figured it should stay.
I decided it needed to be hooked to the bottom like it was before.
Overkill? ...maybe. but it was fun Big Grin
Before:
[Image: 12609284296.jpg]
After:
[Image: 12811594655.jpg]
[Image: 12811594738.jpg]
[Image: 12811594727.jpg]
[Image: 12811594757.jpg]
Lookin at the pictures, I may not have needed to cut as much of the brace off as I did, but what's done is done.
You get an idea of where the bumper/grill will be now with it back on. The flat/horizontal part mounts to the top of the bumper with the grill directley above it. Most, if not all of the IC will be behind the bumper. Between the electric fans and airflow from the car moving, I don't think this will be an issue.
...now for the plumbing...
Buck Choklit Offline
No suck thing as a hack job on a Turbo Ford. Smile
No
jmthunderbirdturbo Offline
nice job!!!
-i screwed an NPR to my rad support, and called it good. took me 2 hours, and it looks stupid. but it works!
-J0N
