347BIRD
May 2019
ST CHARLES, MO
I have a q to all the guys who have already done this mod to their vehicle...
Is it worth it to get a fmic from stinger? Does it include a lot of modifications???
I feel like most guys that have done this mod run in to some type of fitment issue....???
Im just looking to blow some tax money and not really concerned w/how much power it makes as my car is not a race car or fast by any means. I just want a nice driver
1988 Blk T-Bird, 5-spd, Raven int, 3G Alt, K&N conical, Boost controller, ported E6, ported and polished IHI @ 16 psi, 03 Cobra wheels, 255/40/17, 275/40/17, SN95 BBK lowering springs, SN95 Koni struts and shocks, Maximum Motorsports C/C plates, SN95 BMR tubular A-arms, Aluminum driveshaft, LED's, 255 LPH
Mikey97D
Jan 2018
CONNECTICUT
I have no experience with the fmic or bov that goes with it. I did read somewhere on Facebook where a person warned there was some driveability issue from the BOV in a certain circumstance. I did ask if they were using a dual or single piston BOV but didn't get an answer.
347BIRD
May 2019
ST CHARLES, MO
(03-03-2020, 06:10 PM)Mikey97D Wrote: I have no experience with the fmic or bov that goes with it. I did read somewhere on Facebook where a person warned there was some driveability issue from the BOV in a certain circumstance. I did ask if they were using a dual or single piston BOV but didn't get an answer.
thats what scares me is everyone ive seen, the person had an issue.... I'm looking for something completely bolt on and go
John B
Dec 2015
New Jersey
I don't have experience with Stinger's FMIC but from what I've seen and heard from others, the install is very straight forward. IMO, it is a must have upgrade if you want to run higher boost. The stock IC is not terrible but a FMIC like Stinger's is more efficient at cooling intake air temps.
As far as BOV's go, if you are still running the VAM, then go with Stinger's Dual Piston BOV. It is designed in a way that will not leak air during idle or part throttle. If you're running a speed density setup (PimpX, Squirt, etc.) then the type of BOV does not matter. I have the dual piston BOV and used it before I went with a standalone ECU. I never experienced any drivability issues.
Mikey97D and 347BIRD like this post
I bought the Stinger FMIC and tubes and had to make a few cuts with a hacksaw and used a file to clean up the ends.
The first cut was the tube coming off the turbo cause I added a blow off valve and that also pushed the FMIC forward so I
had no clearance issue with the AC condenser. The next was the pipes to the throttle body. I have the 120 degree intake so I installed them
and let the ends sit side by side and draw a line across and took them off and cut them to size. As for the FMIC mounts I just used some flat steel and made some L brackets and screw them to the top of the radiator frame. Also had to cut the bottom of the hood mount bracket to clear the FMIC.
It's not hard just takes a little time and planning before cutting.
347BIRD and Mikey97D like this post
RC Martin
Mar 2006
Colorado
FMIC was a great performance boost for me. I used a different bolt in kit. Just be aware that bolt on still means you may have some figuring or problem solving as you go.
347BIRD
May 2019
ST CHARLES, MO
(03-26-2020, 01:00 AM)RC Martin Wrote: FMIC was a great performance boost for me. I used a different bolt in kit. Just be aware that bolt on still means you may have some figuring or problem solving as you go.
OK, great thanks for the info! I think im going to blow some stimulus money on the FMIC kit from stinger. Theirs seems to be a good kit and Id be able to get some assistance if needed.
brokenbirdy likes this post
