This morning i wanted to fix the timing so i sure did..and now i can feel more power under the hood then before..it was off by about 5, now its up to about 18, 19 (supposed to be 20) but i got it close enough that i could. But coming home from a familys members today..i ran over a nail..and sure enough like a hour later sitting on the rim  but i took it up to the repair shop and those a-holes are the most friendly guys in the world  Feels good to get some power now..(Now if i can find ahole T3 to put in)
Dan
88 T-Bird pretty much all STOCK! (dont have much money to put in her)
Timing is suppose to be 10* with the spout out. Some of us run a little more but 18 to 20 is pretty high for a stock motor. Consider cutting it back to 12-14*
I have this Thunderbird/Couger Book and it has specs for a 88 and it says 20 for some reason..and i have a timing gauge and it says 20 is normal so i dont know?
Dan
turbocoupes
Jul 2003
Aberdeen,Maryland
I WOULD NOT run more than 16 spout out...ask me how I know...
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Ok ill back it down
Dan
Quote:I have this Thunderbird/Couger Book and it has specs for a 88 and it says 20 for some reason..and i have a timing gauge and it says 20 is normal so i dont know?
May I suggest some quality time with the search feature, keying on "ignition timing"
Well see this might change some things..see i used a vaccum gauge since i didnt have that cover
Est at 8-10
Sry about the mix-up
Dan
Gotcha. I would get a proper cover and get it timed with a timing light. Any 2.3 OHC cover will work. Does not have to be from a turbo motor.
yeah i found one at the junk yard good shape going to put it on tomorrow
Thanks for the help
Dan
martin0660
Jun 2002
Greensburg, PA
Okay, I'll bite, how do you know? :eek:
Its not like you arent enjoying all the work to put it back together right?
Bob Myers
