Matt S
Mountlake Terrace, WA
Still doing my 134 conversion.
Blasted rain!!
But now I have the heater box out. I'm going to flush everything today and tomorrow.
My question is about the orifice tube. I bought a new one for $4, but the haynes book mentions needing a special tool? Is replacing this thing possible without the tool? Is it even necessary?
Sold it  *
Dont fix what isnt broke. If the orifice tube isnt plugged up, just leave it.
Matt S
Thought I had to do it with the 134 conversion. But looking around I see not many do and their A/C works fine. Thanks for the reassurance, Jeff.
Sold it  *
The original orifice tube will work fine with 134a. Since the pressure / temp relation is a little different for 134a, you can help things a little by slightly reducing the pressure the CCPS (switch sticking straight up out of the accumulator with 2 wires to it) cycles at. Remove the connector, and you will see a screw. Turn the screw 1/8 to 1/6 turn counterclockwise to lower the turn on and turn off pressure by about 3 psi.
