Felpro Turbocharger Mounting Set
This is the Felpro Turbocharger mounting Set that includes several gaskets including the metal embossed gasket for between the turbo and the exhaust manifold. The kit number is ES 72811. Any place that handles Felpro should be able to order it.
Below is a list of what is in the kit and the individual Felpro part numbers.
* 2503 - Embossed manifold (turbo to exh manifold, metal gasket).
* 92622 - Turbo flange for the oil return line.
* 92960 - turbo to throttle body (this is for the 83-86 cars w/o inter cooler.)
*93848 - oil return line (the reason there are two different gaskets listed is that the T3 and the IHI turbos take a different gasket.)
* 9398 - air inlet connector (I think this is the one for the inlet tube on the front of the compressor housing. It works with either turbo (T3 or IHI) because the inlet tubes are the same size at the mating face. I'm using an IHI inlet on my T3.)
OU812MACH1 Offline
felpro #es72811 turbo mounting kit 5 gaskets in box
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
