Fans won't turn on
AeroDog Offline
My fans suddenly stopped turning on as temperature rises. If I activate the a/c, they turn on. I'm new to TurboCoupes and just bought this car (an 88). As I've poked about the car I've found several connectors not connected to anything, however everything on the car works (Power sun roof, cruise, etc). Any ideas?
88 TC, MAF conversion, Gillis, Front mount IC, multiple oil leaks
fierospeeder Offline
I dont have my manual with me and it has been a while since i worked on my car.
I would check to see if the temp sensor/switch is working. You can always jump the switch and see if it turns your fan on. First, look in the wiring diagram if you do this.
Welcome
Here is an article on fan diagnosis: http://www.turbotbird.com/techinfo/Cooli...ingFan.htm
here are a couple links to useful information http://www.turbotbird.com/FAQPage/FAQpage2.html
If your not familiar with the terms and abbreviations we use, see the link to them just on top of the grid
Technical Article at: http://www.turbotbird.com/techinfo/techarticles.html
There are a lot of past posts on the cooling fans so this will help also: http://natomessageboard.com/cgi-bin/sear...tion=intro
Joe F Offline
First, here's a pix of sensor locations. The fans are triggered by the ECT sensor.
Second, here's a link to troubleshooting the cooling system.
These articles, and lots, lots more, are in the Tech Articles section.
HTH. Edit - Pete, do you ever sleep? [Image: biggrin.gif]
Be Cool,
Joe
JR's Place - My 87 TC
[This message has been edited by JoeCool (edited 01-12-2005).]
PetzJC Offline
As old as Pete is, I'm sure he gets a few naps in during the day...
88 Silver T/C, original owner, 258,000 miles.
Loaded with everything except leather & auto trans.
Short block & turbo original/untouched.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
AeroDog Offline
Thanks, guys. I'm shocked at how helpful people on this board seem to be. I realize (somewhat belatedly) that I should have done a search on this topic before asking questions. I'll learn. Thanks, again.
Jerre
