fan switch question
cammed99 Offline
I would like to wire at least one of my fans to a manual switch, can I just follow the instructions for the 83-86 cars in the faqs? I've never wired anything "correctly" and I would like to do so this time with the correct relay and what not. I can wire it up with no relay and just to a hot source like I've done things on other cars but I'd like everything to be ok for a long time afterwards.
88 turbo coupe, 5 speed, stock Big Grin with a gillis valve and 3 inch downpipe and exhaust, ported exhaust side on the head, fresh bearings and rings, fresh head, mustang roller cam, .60/.63 T3 and now someone needs to give me a header
4 other vehicles, all fords and all unique
89 TTA (yes the turbo one)
65 Mustang Fastback 2+2
98 GT
99 Ram 2500 4x4 Cummins on 35's
82 Bronco 4x4 FOR SALE
tylerport Offline
Yes, you can follow those instructions. Using a relay keeps the high amperage draw that a fan motor has from melting the switch an it also shortens the path for the high amp load.
Jim Portteus
My Car
86 Turbo Coupe, LA3 w/ Intercooler and Larger VAM, Gillis Valve, 2 1/2" Downpipe to 2" Duals w/ 18" Glasspacks, 245/50R16's, 140MPH Speedo, A-pillar pod w/ Boost and A/F Ratio Gauges and Steeda Tri-Ax Shifter.
Jim Portteus
Never wire a high amp load like a fan to an existing circuit. Power the fan via a relay, with the high current side of the relay coming directly from the batt pos terminal or hot terminal on the starter solenoid. Use a switch to trip the relay.
tylerport Offline
. . . and don't forget to use a fuse or circuit breaker to protect the new wiring! It should be installed as close to the Battery as possible. Don't want it shorting out and causing a fire.
Jim Portteus
My Car
[This message has been edited by tylerport (edited 05-31-2004).]
Jim Portteus
