The previous owner hard wired a switch directly from the battery and I would like to put it back to factory specifications. Does anyone know where to locate the correct fan control module
86thunderchicken
Jan 2011
Salem, Oregon
I believe the fan controllers are behind the glove box kind of or behind the dash near the steering column on the lower half
1986 TC 240,000 miles. Walbro 255. Soon to be under the knife for an 87 5 speed swap
1992 Mustang LX 5.0, headers, H pipe, and soon to have subframe connectors to boot!
^^^^ +1 Behind the glove box.
The fan control module is a VERY common failure.
Where can I find a replacement for sale? I'm looking all over the internet and can't find any
The module isnt anything special..... it is just a high current 40 Amp relay triggered by the coolant temperature switch in the lower intake, along with a trigger to turn the fan on when the AC compressor is energized. If it were me, I would just build my own controller with a 40 A relay to turn on the fan triggered by the temp sensor, and a second small relay triggered by the power feed from the AC compressor clutch coil to turn the fan on with the AC.
86thunderchicken
Jan 2011
Salem, Oregon
Can you show a rough sketch wiring diagram of your idea? lol
So easy you dont need a diagram...... Fan switch on intake grounds when fan should run. Grab key in run power from somewhere, Run to 1 40 A relay coil terminal. Other coil terminal goes to fan switch on intake.18 AWG wire is fine for these runs as current is very low (around 100 mA). One normally open relay terminal goes to battery using 10 AWG wire with a 40 A fuse. Other relay terminal goes to fan + terminal, again using 10 AWG wire.
86thunderchicken
Jan 2011
Salem, Oregon
Jeff any way you could show a picture of the diagram with what you would do? I’m a very visual learner it helps immensely
RC Martin
Mar 2006
Colorado
On my 84 it was the temp switch itself that stopped working, a new one was something like $6 at rockauto. It also comes on very late, at 220F -- this is the OE design.
